:: Which Frame on a Citta?
Home Forums English General questions Which Frame on a Citta?
  • #144373
    ECO
      Hello,
      I´m Simon from Germany (sorry for my bad english!) and I´m a proud member of an Gilera Citta. But I don´t have a frame for the engine (I hope you know what I mean) I´d like to now which frame fits, because Citta parts in German are very rare. I know i can take a Si frame, but i´d like to make wheelies and I think he is longer and increased the wheelbase? Fits the Bravo Frame? (Sorry that i couldn´t take the search function)
      Thank you and many greetings to the netherland.
      Simon
      #146270
        Hello Simon,
        A lot depends on which front fork you have, if you have the front suspension of a Citta, it could fit eventually in a Ciao frame but not in a Si frame.
        What parts of the Citta do you have then? The engine, the rear swingarm and the wheels? Or do you have suspension and steering of a Citta as well?
        A Si frame is indeed a lot longer than a Citta frame..
        Greetings as well!
        Edit: Aha now i see you where talking about the subframe i thought you meant the frame of the whole bike 🙂
        You could use the one from a Si as well but yes it will have a longer wheelbase then..
        #146271
          You can use a bravo subframe, shouldnt be hard to find in germany and otherwise there are plenty available here.
          A better option is to make one yourself, because the standard ones are quite weak. Or you could strengthen an original.
          Good luck.
          #146272
          ECO
            Hello,
            thank you for your answer. Off course I meant, which rear swingarm fits on an Citta frame.
            But I don´t now the word “rear swingarm” 😀
            Thank you at all!
            But one more question, can i put the Citta “Motorschermen” on an Bravo subframe?
            Greetings,
            Simon
            #146273
            Spulleke!
              yes that’s possible
