:: Which cylinder manufacturer?
Hi,
I have two 43mm cylinders and I’m not sure about the manufacturer.
The only marking on the cylinder is the letter “Y”, the piston is marked with “ASSO” but I guess most Piaggio pistons are made by ASSO in italy?
The cylinder head has no markings at all but is a 43mm head.
I will put up a picture tonight
Any ideas?
/Dea
Thanks!
Is it considered to be a good cylinder?
/Dea
After 1500 kms with an Athena/Eurocilindri 50cc I’m going back to the Olympia 65cc cylinder.
Performance was similar but the Olympia 65cc has much better low-end power.
