:: Which brand of cylinderkit best fits on stock carter – CIAO
Hello!
– two questions:con
I’ve heard that malossi 43 kit with triangular shaped ports fits better on stock carter (without matching case) then DR 43 EVO or Polini 43 because they have D shaped ports. What do you think or do you have any experience with this??
Does standard decompresion set fits in a malossi HD cylinder head without problems or do a I need decomp set special from malossi.
Thanks for your answers
hello!
a lot of people drive the DR Evo, i am fairly sure most people prefer the DR over the Malossi.
maybe the port dont match that well, but the DR is really fast out of the box, and a lot cheaper.
The decompression does fit, the special decompression sets are for DEPS cilinder heads only
SuperSi :
hello!
I have very good offer for the malossi kit 43 with head so I wonder is it an equal quality like DR evo 43 cylinder.
What do you think about OLYMPIA kit 43 – also includes head and is cheaper than malossi and DR evo? is that also a good choice?
Thanks for yor answer
Ruby,
The malossi is rubish quality i won’t recommend it.
The DR is a good cylinder and also the Olympia (old type DR) is a good fit with good quality.
Lennaert :
Ruby,
So you reccomend me an OLYMPIA rather thn malossi?? Why do you thinh that malossi is rubish, just answer?
Hello Ruby,
I recommend a DR or a olympia.
The malossi is just bad quality many wear of in about 3000km’s or less the DR/Olympia will run beyond that without too much problems.
Lennaert many thanks for your answers;)
