:: Wheels, rims and tires – do they affect top speed?
Home Forums Techniek Framedelen Wheels, rims and tires – do they affect top speed?
  • #815303
    benex
      Hello 🙂
      Recently i have changed wheels and tires in my Si Mix and i noticed that max speed is lower than on original setup.
      Original setup, 47 km/h:
      – triple spoke rims (picture 1)
      – Pirelli tires 2,5*16” (pictures 2-5)
      New setup, 44 km/h:
      – four spoke rims from Bravo (picture 6)
      – Duro tires 2,5*16” (pictures 7-8)
      Is it possible that Duro tires and/or four spoke rims dont allow to go faster?
      1
      1
      2
      2
      3
      3
      4
      4
      5
      5
      6
      6
      7
      7
      8
      8
      #815320
      SuperSi
        I know tire pressure can affect top speed a lot so maybe check that?
        #815338
        niek1992
          In the end it comes down to rolling resistance. As SuperSi points out, tire pressure can affect top speed because it increases rolling resistance. I couldn’t find numbers on the differences between ‘offroad’ tires and ”semi slick’ ones regarding rolling resistance. However i did find sources that state that rolling resistance can be lowered by lower thread depth.
          Energyloss occurs when the tire has to roll through it’s footprint and is turned into heat. This energyloss is compensated by the engine. And since our engines don’t have much available horsepower and you’re talking about topspeed, this means topspeed isn’t as high as before with a ‘difficult’ tire.
          #815351
          benex
            Ok, thanks for the answers. I drive a lot in light terrain/forest roads/road not paved so i need tires with deeper thread. But maybe there are some tires that allow higher speed on the roads and better grip in terrain.
            #815352
            Wim
              Is a brake cable stretched too tight?
              Or did you also replace the rear transmission with the new wheel?
              There are several of them.
              #815366
              benex
                The brake can’t be too tight. It is the same as i was before, when moped was running faster. I did not replace the transmission. It is the same as before, original, single speed, non varieted transmission. I just cleaned it and changed the oil.
