- Dit onderwerp bevat 11 reacties, 7 deelnemers, en is laatst bijgewerkt op 15 jaren, 2 maanden geleden door hansieb.
12 januari 2011 om 12:29 #147450
Hello guys:)
I have a problem with my Malossi deps and Simonini sideinleet 🙂 Im afraid that i will loose allot of effect becuse of this 🙁 What would you guys do?
Sorry for the bad english.
From Sweden12 januari 2011 om 12:34 #147838Mill away a part of the cilindersleeve. Has been done many times before and works perfectly.
Home made engine dyno12 januari 2011 om 12:36 #148055ArvidW :
Mill away a part of the cilindersleeve. Has been done many times before and works perfectly.I was thinking that:) But I wanted to make sure that there is no problem with that 🙂
From Sweden12 januari 2011 om 12:42 #148056This modification is also neccesary when you mount a simonini 48mm on this crankcase. For some weird reason Simonini didn’t bother to do it in the factory:?
(modification done by Speedbuxy)
Home made engine dyno12 januari 2011 om 12:47 #147977but that is a big deps alu?
that`s a very precious (zeldzaam) cylinder .
i shouldn`t do that !!
it`s better but the cilinder is not available anymore!
but you need to no it self , but wen i had so a cylinder i didn`t do that12 januari 2011 om 13:38 #148057kevin 27 :
but you need to no it self , but wen i had so a cylinder i didn`t do thatYes its a alu deps 🙂
ill think ill skip to fix that right now 🙂 maybe later 😉
From Sweden12 januari 2011 om 16:18 #148058Perhaps malossi is going to reproduce the Deps cilinders again, then they won’t be rare and you can cut it :lol
12 januari 2011 om 16:41 #148059hansieb :
Perhaps malossi is going to reproduce the Deps cilinders again, then they won’t be rare and you can cut it :lolHaha yeah sure 🙂
From Sweden12 januari 2011 om 16:45 #148061hansieb isn’t joking, dude 😉
12 januari 2011 om 16:46 #148062hansieb :
Perhaps malossi is going to reproduce the Deps cilinders again, then they won’t be rare and you can cut it :lolI thought some one here on the forum sent malossi an e-mail about this? What was the answer?
Excuse me for asking a question here on your topic!
12 januari 2011 om 16:51 #148060Color the part so you know exactly what you can mill away.
If you do I think nothing will go wrong 😉
Don’t be afraid because it’s just a few mm..12 januari 2011 om 16:51 #148063It’s still not confirmed, but perhaps we can push them. They also started to produce the RV engine again.
A spokesperson of malossi germany is registered on the german forum, so perhaps……
