:: What weights in a Polini Speed Control?
Home Forums English General questions What weights in a Polini Speed Control?
  • #144247
      Hi,
      would like to know what weights related to setups you guys have in your Speed Controls.
      Is it comparable to the Multivar weights and setups?
      Means for example, if I have 6,5gr in the Multivar is the same like 6,5gr in the Speed Control with the same setup?
      #145718
      Gerarduz
        The Polini speedcontrol comes with 4,4gr. blue and 5,6gr. yellow weight in roll’s.
        Malossi delivers 4,6gr. rolls.
        It cant make a differance in top speed. The Polini pulls harder! it’s an differance in the angel of degree …
        Malossi 0 degrees.
        Correct me if i’m wrong ..:thumb
        #145719
          What I have experienced is that 7.0grams in a polini speed control equals aproximately 6 to 6.5 in a malossi multivar.
          Mike
            i agree to Arvid, in a speed control you’ll need for the same setup ( with mulitivar ) around 0,5 grams more.
            with my Pinasco 42mm engine, i used an malossi multivar with 6,4 grams. Now i have a SpeedControl and now she drives the same with 7,0 grams
            Mike
            #145721
              ah, that’s good information.:thumb
              Thanks
