:: What Membraanplaatset ?
Piet30Topic starter
Hi,
what experinces do you have with different Membraanplaat thicknesses? Do you use Carbon or Carbonite?
My only experiences goes for the thickness of the valves. Don’t know the differences between Carbon or Carbonite or even other materials for that matter.
With a thicker size, the motor runs more explosive but a bit less smooth. On the other hand if you have a big cylinder. A too thin membraneplate is more diffecult to adjust fine tune. Especially for the stationairy part.
Piet30Topic starter
yes, that’s what I have heard too. What membraan thickness are you guys driving?
0,25mm or 0,35mm or even thicker on what cylinder ?
