:: What belt do I use?
Home Forums English General questions What belt do I use?
  • #144138
    deanhatesyou
      What belt do I use on my ciao with a variator? I took the wheels and motor from my Bravo after I broke the frame and put them on my Ciao frame, I’m having a hard time finding a proper belt, though. Where do I find one that is the proper length and width?
      #145434
        You need 13mm width and 950 / 975mm long.
        You can order a malossi variator belt.
        or you can get a belt at the normal size.
          You can find it in a store for automobile parts, they usually have every size and shape belt.
          #145436
          deanhatesyou
            Thanks a lot guys. I did check a couple auto part stores, but there’s not a lot of metric belts around for some reason.. doesn’t make sense to me considering most of the cars around are foreign..
            Who carries the Malossi belt?
            #145437
              Our webshop jmpb.nl sells them, mopshop.de(german).
