:: GZ: Wanted Fabrizi 48mm kit
Hi all,
I am looking for a Fabrizi or Simonini 48mm kit : piston(pen 12)/cylinder/head, also used is ok.
This is to repair my Simonini 48mm full engine.
Please help^^
Thank you
If you don’t got a 46mm crankshaft , I would go for the pinasco black.
Simonini 48 mm it’s not best cylinder for you engine 😉 and fabrizi 48mm is not easy to find.
The pinasco you can order on eBay
Thank you for info^^, unfortunatly i have a 46mm cranckshaft, grrr..
Effectly Simonini 48mm 3p are out of price now !
Is there any solution you know ?
Thanks
The easy solution is to get another crank like the mazzu atm206 with the pina 46mm .that would be on eBay 325 euro. Then you blow the tiles of your streets :p a Dutch saying
Well, you are right , but i have to do as less expansive as possible. So the pinasco black 46 has a stroke of 43mm, right ? So i will made a 3 mm aluminium wedge between carters and the cylinder.
So i’m looking for a second hand pina one^^
