:: Vespa Ciao Pull Start
Home Forums Algemeen Overige algemeen Vespa Ciao Pull Start
  • #781752
    LSL
      Hi,
      Does anyone have any experience buying a pull start from elevation.nl?
      BR
      LSL
      #781754
        Many of this forum are using from Elevation  The owner from elovation is also on this forum. Great product!
          I have one, for 2 jears now, and I am verry pleased with it. Starts great even with 43mm or 46mm cilinders.
          To enjoy it for a long time, you have to make sure that the alignment is optimal, otherwise the inside will wear away in no time.
          #781790
          LSL
            Ok, thanks for the answers. Does they usually ship within a few days?
            I ordered one on elevation.nl almost 2 weeks ago, and I still haven’t received it. When I log on to my account the order status just says “Pending”. I wrote the shop several times, but haven’t received any answer other than order confirmation a couple of weeks ago.
            /lenn
            #781792
            AA-T
              I’ve contacted him personally and expect he will answer in a considerable amount of time. Usally his service is very good so there’s probably some mixup of some kind, or mistake.
              #781836
              LSL
                Ok, then I guess that I have just been unlucky. I have wrote him 3-4 times within the last 13 days, – but haven’t received an answer yet. Unfortunately the pull start kit should have been used as a Christmas present.
                #781862
                AA-T
                  You might have noticed we experienced some troubles ourself with the webshop. Looking at elovation.nl I can tell he uses the same software for his webshop. That would explain a lot, but for you it’s definitely unlucky.
                  You can always print an image on a card saying it’s on his way 😉
                  #781894
                  LSL
                    I have tried to cancel the order via PayPal and then placed a new order.
                    #781901
                    El Citta
                      Hi LSL,
                      Something went wrong with my webshop. It’s currently fixed and I received your order. Today your package will be send.
                      Keep an eye on your email because you will receive a message with your tracking code.
                      #781903
                      LSL
                        Thanks. Looking forward to receive the parcel 👍
                        #781906
                        AA-T
                          Glad to see it’s been resolved. You might even be in luck and receive the parcel before christmas  😎
