:: Vario belt Malossi on 90 mm vario – CIAO
Home Forums English General questions Vario belt Malossi on 90 mm vario – CIAO
  • #144171
    rubymax
      Hello,
      Is there any problems to put malossi variator belt (978mm lenght) which is constructed for 100 mm vario pulley on 90 mm vario pulley.
      Thanks for answers
      #146485
      niek1992
        you’ll not be able to tension the belt properly without modifying your frame so your engine can be moved more to the front.
        #146484
        freddy k
          It will be a bit to long maybe if you put the engine as far as possible to the front.
          Mine’s running with a 950mm belt on 100mm disks but the belt is to short.
          friendly regards.
          #146171
          rubymax
            I’m asking this because I’ve heard that malossi is very strong – long life belt versa other producers . I don’t know which producer for vario belt (950 mm lenght)for 90 mm vario is the best solution to buy.Maybe some advice which vario belt for 90mm vario, I know the lenght is 950 mm.
            Regards
            #146170
            freddy k
              I use continental belts my malossi broke after 500km’s :/
              My continental is running on a fox clutch and is available in many different sizes.
              #146486
                It should be possilble if you could use a tensioner
