:: Type of crankschaft ?
Home Forums English General questions Type of crankschaft ?
  • #792249
    jacekniemiec
      My friends,
      please let me know with tipe of the cranschafts ..
      I have two typees of it :
      one with holes in the counterweights, other is without it ..
      I am puting toegheter one engine for carb 12.10. Witch crankschaft i need to use .?DSC_0221DSC_0222
      #792268
      Crullie
        First foto(with holes) is a old-timer crankshaft with a 12 mm pistonpen conrod, the other one is a newer type crankshaft with a 10mm pistonpen conrod, so depending of the cilinder and piston you will use 12 or 10mm pistonpen the choise is yours :thumb
        TICKLING BARN
        #792276
        jacekniemiec
          Thank You , my Friend !
          Can You tell me if first picture crankshaft  – with holes  – have any thing to do with the power/speed limit (Duch model) ?
          Or it not matter  – I mean the limiting the size of the gas room , or speed of the intake mix flow through the crankshift box …
          Or I am ‘loco’  😉  ?
          #792278
            No. It was meant for a tool to get the crank easier in the case 😄
            jacekniemiec
              Thank You, my Friends for Your help !!
              All the Best in New Year !!!
