:: Tuned 47mm D.E.P.S
Home Forums English General questions Tuned 47mm D.E.P.S
15 berichten aan het bekijken - 16 tot 30 (van in totaal 30)
  • #145690
      I’ll tell you one thing, I have a tuned deps(lots less extreme), and it’s noisy! It sounds great(malossi tb), like a racebike but you need a better silencer to keep it ‘civilized’.
      #145691
      Nichoo
        Edjuh :
        Thanks for the advice, although this cylinder will almost only be used for short track races:)
        #145819
        bowie82
          is this a good cylinder? there is someone in the states selling one with a polinni circuit exhaust for pretty cheap. the exhaust also has a 27mm flange on it. the cylinder was never ran, and comes with piston, and everything. what case is best for this cylinder?
          #145820
            you really should buy it.
            d.e.p.s are real nice whit ports and quite fast thats the build for them.
            average d.e.p.s get a higher speed seeing other sets.
            you will be making the right choice to get one.
            #145821
            Zeebodem.
              the best casses are malossi reedvalve;)
              #145547
                To create a little buffer against overheating and risking your piston to get stuck, you could lay the spine back a bit. Just hollow it a fraction which will give it that little bit extra room for expansion.
                It’s done before by tuners with the thin/extreme tuned spines.
                #145838
                bowie82
                  can you run this cylinder with a polini speed case? if so what needs to be done to the case?
                  #145839
                    It is possible, but the inlet of the Polini speedengine is not bigger than 13 mm.
                    But when you gonna use an speedengine, you have to make the big boosterport like this:
                    #145842
                    bowie82
                      so will i also need to block off the other transfers like you did in the picture? will this still perform well with the 13mm intake?
                      #145843
                        no that is not necessarily. It will perform with an 13mm intake, but on a 47 DEPS I would use an 19mm carburator.
                        #145870
                        bowie82
                          what head are you guys running on these 47mm deps kits? thanks.
                          #145871
                            The kit version of this 47mm Malossi Deps came with an high pressurised 47mm head. But since the exclusivity of this head alot are using other heads like the normal Malossi 46,5mm. Keep in mind you can always mill the bore of a smaller head a little bit bigger until it matches 47mm.
                            #145873
                              bowie82 :
                              http://www.jmpb.nl/store/index.php?act=viewProd&productId=607
                              #145879
                              bowie82
                                hey hansieb. will that citta head fit in a ciao fram, or will i have to grind down the side fins? thanks.
                                #145880
                                Mike
                                  you only need to grind them at the left side;) and just a little on top.
                                  Mike
