:: TK: Sprocatti motori engine
Home Forums Advertenties Onderdelen aangeboden TK: Sprocatti motori engine
4 berichten aan het bekijken - 16 tot 19 (van in totaal 19)
  • #247148
      Laten we het erop houden dat het in ieder geval geen plug and play is. Je zit bijvoorbeeld met een 46mm slag krukas en een cilinder die ontworpen is voor 39.2mm slag.
      ciaomalossi
        ArvidW :
        oke kijk dan heb je er ook niet zo veel aan dus :thumb
        #247220
        Kamelen
          ArvidW :
          I’ve done the modifications except for the portlowering.
          I’ve milled the adaptorplate , the squish is set to 0,5mm with thinnest gasket.
          I also milled topchamber of the cylinder.
          #247142
            Okey, I didn’t know as it was not mentioned in your project topic.
            Edit: I did some calculations.
            S6 R/T on a minarelli scooter:
            Bore 47.6mm
            Stroke 39.2mm
            Swept volume 69.76cc
            Rod length 85mm
            Exhaust port height 22.5mm
            Transfer port height 32.9mm
            Squish 0.4mm
            Head depth 2.4mm
            Deck height 2.8mm
            This gives 192.67dg exhaust and 127.55dg transfer port timing, which is pretty good for a high reving 70cc racing cilinder.
            S6 R/T on a sprocatti engine:
            Bore 47.6mm
            Stroke 46.0mm
            Swept volume 81.86cc
            Rod length 90mm
            Squish 0.5mm
            Head depth -0.5mm (I guess you milled the top chamber so that piston @ TDC gives deckheight of 0mm)
            Deck height 0mm (piston flush with cilinder @ TDC)
            This gives 197.11dg exhaust and 143.46dg transfer port timing
            The 46mm long stroke really screws up the port timing, especially the transfer port timing. That’s nearly 10dg more than normally is considered “the maximum”. Even if you have a deckheight of -2mm (so piston protrudes 2mm from the cilinder at TDC) you still would get 132dg transfer port duration. How did you want to solve this problem initally?
