:: TK: Sprocatti motori engine
Home Forums Advertenties Onderdelen aangeboden TK: Sprocatti motori engine
15 berichten aan het bekijken - 1 tot 15 (van in totaal 19)
  • #246086
    Kamelen
      Sprocatti disco rotante carter (28mm inlet)
      Sprocatti crankshaft 46mm 90mm rod 12p
      PVL Analog ignition rotor
      Stage6 R/T 70(83)cc
      JS-tuning JS80 exhaust pipe
      28mm Keihin carb
      Stage6 Bell Mouth
      Variokit with:
      Polini SpeedControl(never used , only mounted)
      New Malossi belt Bravo/Superbravo
      Piaggio original clutch
      Gearing, hub etc
      Pics:
      Price: 450 euro + shipment , contact me at sjrwessung@hotmail.com
      Price for new parts:
      Sprocatti disco rotante carter (28mm inlet) – 245 euro
      Sprocatti crankshaft 46mm 90mm rod 12p – 126 euro
      PVL Analog ignition rotor – 245 euro
      Stage6 R/T 70(83)cc – about 320 euro
      JS-tuning JS80 exhaust pipe – 220 euro
      28mm Keihin carb – 130+ euro
      Stage6 Bell Mouth – 15 euro
      Variokit with:
      Polini SpeedControl(never used , only mounted)- about 80 euro
      New Malossi belt Bravo/Superbravo – 15 euro
      Piaggio original clutch – 160 euro for complete variokit with this vario
      Gearing, hub etc – 160 euro for complete variokit with this vario
      Total: Things for about 1400 euro.
      My price: 450 euro.
      #247230
      Kamelen
        Lowered price by 100 euros
        Buy Sprocatti carter , crankshaft and ignition for 250 euros.
        #247205
        bartklumpenaar
          The clutch of the vario
          Is it 90 or 100mm?
          #247176
          Kamelen
            bentwi :
            Is it 90 or 100mm?
            90 I think
            #247249
            bartklumpenaar
              can u measure it for me?
              if it is 90mm i want to have it
              What is your price?
              #247025
              Mark Lundahl
                Nice engine….
                Does everything works??
                Do you know were you can buy spare parts for the engine??
                #246991
                Kamelen
                  The shipping cost is 155 euros incl exhaust.
                  (600 euros incl)
                  #246992
                  Kamelen
                    Mark Lundahl :
                    Nice engine….
                    This is not a running engine.
                    You need to lower the ports so the piston is in horisontal with the ports in bdc.
                    You need to buy new gaskets and screwset (about 30 euro max)
                    #246993
                      Kamelen :
                      (600 euros incl)
                      Thanks for the shipping quote Kamelen 🙂 Unfortunately 600euro is too expensive for me 🙁
                      ciaomalossi
                        Hallo
                        Wat wil hij nou voor alles hebben met opstuuren.:?
                        #246844
                          Staat er toch? 600.
                          #247076
                          Kamelen
                            550 euro is my absolutely last price , since I need the money.
                            #246846
                            ciaomalossi
                              Tonni :
                              Staat er toch? 600.
                              Ja zal wel maar ik kan er niet zo veel uit wijs worden ,maar is het wat voor dat geld 8)Tonni
                              En is het allmaal compleet. En past het allemaal onder een ciao.
                              #247238
                              jordykee
                                Het is compleet maar loopt niet, leer lezen.. zo slecht omschrijft hij het nu ook weer niet
                                #246827
                                ciaomalossi
                                  jordykee :
                                  de een kan beter lezen dan de ander hi:pest
