:: TK: Custom side-inlet engine!
I’m selling my motor, it’s BRAND NEW, NEVER STARTED OR FULLY ASSEMBLED!!
The motor is custom built side-inlet high-power motor, with a lot of potential!!
The side inlet timing is the same as Simonini.
-,Carter/Crank case = Polini speed engine points ignition (130€)
-,Ignition = HPI inner rotor ignition (234€)
-,Malossi Manifold (Reed) 21mm (60€)
-,Pinasco black 75CC (open boost ports) (178€)
-,Malossi crankshaft bearings (22.50€)
-,AMT002 crankshaft (89€)
-,Dellorto PHBG 21mm (95€)
-,Stage-6 airfilter (35€)
-,Simonini 22mm Calibrata (149€)
This engine have costed me around 984€ (!!!) in only parts, then add up the labour for welding and machining.
Bids start at 500€+35€ shipping!Paypal is accepted, but you pay the paypal-fees.
This is a brand new one-off engine, custom built and never before started!
I will include som small parts, not listed, such as gaskets, choke parts and some bolts.
EDIT: Put in the Simonini Calibrata in the ad..
Added the simonini calibrata to the package 🙂
