:: TK: 101mm semi-pulleys correctors CNC cromed simil teknoetre
Home Forums Advertenties Onderdelen aangeboden TK: 101mm semi-pulleys correctors CNC cromed simil teknoetre
4 berichten aan het bekijken - 16 tot 19 (van in totaal 19)
  • #249772
    gab_pei
      the angle will be the same.
      #249773
      R.Zwiers
        But then you will need a thicker belt I think because the highest part will be more then 13mm is suppose? Correct me if I am wrong
        #249774
        Vespaatje
          R.Zwiers :
          Yeah, i was thinking about that too 😕
          Or it won’t variate as much as the 100mm pulleys do.
          #249775
          gab_pei
            sold-out
