:: TK: 101mm semi-pulleys correctors CNC cromed simil teknoetre
Home Forums Advertenties Onderdelen aangeboden TK: 101mm semi-pulleys correctors CNC cromed simil teknoetre
15 berichten aan het bekijken - 1 tot 15 (van in totaal 19)
  • #246408
    gab_pei
      101mm semi-pulleys correctors CNc
      materiale: c40, cromed
      with measure tecnkoetre
      increase recovery, more robust, Most quality materials, greater duration
      only 10 kit available
      60 euro + shipping
      #249758
        Very nice parts !
        #249760
        gab_pei
          thanks.
          #247965
            90mm?
            #249761
            gab_pei
              101mm
              #249762
                Do they variate more than the original 100mm?
                #249763
                gab_pei
                  yes, there is an increase of velocity and acceleration.
                  #249734
                  R.Zwiers
                    Looks fantastic, wandering how much performance will increase with these pully’s, do you have used them/ tested them? Or what can we acspect?
                    How much are the shipping costs? 16,-?
                    #249764
                    Vespaatje
                      A test with all 3 different pulleys on the same setup would be nice 😀
                      #249765
                      gab_pei
                        the teknoetre declared a 30% increase . I have not tried but teknoetre yes 🙂
                        belt with these discs falls much more on the disc.
                        17 euro for shipping.
                        #249767
                        TJOEP
                          Hi Gab_pei, can your supplier also make them with a larger diameter? Please let me know.
                          #249768
                          gab_pei
                            the next will have a diameter 108mm.
                            #249769
                            timrex
                              Hi!
                              I take one. I wrote a pm to you.
                              Greetings
                              #249770
                              R.Zwiers
                                Will the 108 mm fit in a si subframe? with the cover in it? And Will the belt still fit?
                                Then i Will wait for that one:D
                                #249771
                                Vespaatje
                                  How much does the angle change with the 101mm and 108mm pulleys?
                                  Mvg
                                  Jeroen
