No problem to copy my design. This is normal in the world of Piaggio/Vespa’s. Even some brands out there will make copy’s of the same products. The thicker waterjet cut gaskets I’ve bought from another forum member, but this was some years ago and this member is not active anymore.
Keep in mind the Graham Bell book is from years ago and not all in there is up to date or will benefit our engines. Although it’s almost a bible for 2-stroke tuners, keep it sometimes closed. For almost every 50cc Piaggio cylinder it’s beneficial to shorten the deckclearance/squish or flatten your head. This is because the squish is already to great a number. We are talking around 3mm squish for example; Click for topic.
The goal is to get a higher compression ratio.
