:: SX3’s Ciao perso [English]
Home Forums Perso’s Projecten SX3’s Ciao perso [English]
15 berichten aan het bekijken - 121 tot 135 (van in totaal 239)
  • #782270
    sx3-swe
      IMG_20181228_152918It’s been a while since last, the raw material for the carter have arrived and I will bring it to mill-man tomorrow. However we’ll probably not mill anything tomorrow he will do it on his own, hopefully during January.
      Meanwhile, I’ll be CAD’ing up a hub for the front rim, to fit a disc brake, just need to get to the workshop and make some measurments of the wheel.
      #782982
      sx3-swe
        I’m awaiting my CNC operator to start mill the case, he has done abot 50% of the toolpaths needed so still alot of work left. Meanwhile, I have cadded up the EBR fork, RPM caliper and the beginning of the hub.. Still awaiting the 260mm disc to arrive until I can make the final adjustments to the hub depth and design to match the disc. The disc present in 3D model is just made out of nothing.IMG_20190115_170700_resized_20190115_050804092IMG_20190115_170711_resized_20190115_050803481IMG_20190115_170719_resized_20190115_050803273IMG_20190115_170725_resized_20190115_050803712bromsokbromsskivagaffel2navgaffel
        #782983
          You are realy good whit cad :thumb
          The disk is a looker.
          #783005
          sx3-swe
            Thanks, but honestly it ain’t that hard! Fusion 360 from Autodesk is a free software and quite easy to use. I started out with Inventor (same as Fusion, but not free) same time as when I started the carter, no previous experience. Fusion can also generate G-code, if you have access to a CNC machine.
            The hard part is to get someone to mill the things, even for me that know a guy having a hard time getting him to mill 😀
            Anyway, the bracket is finished, all I need now is the disc itself, which should arrive next week.gaffelfäste2fäste1
            #783383
            sx3-swe
              Hmm this looks familiar.. Seems like The mill-man actually started to work after some threats. 🙂 IMG_20190126_194556_528Resized_20190126_175230
              #783387
              Crullie
                Looks like porn to me   😎
                Succes     :thumb
                TICKLING BARN
                #783388
                sx3-swe
                  Don’t know if the Dynamic milling, taking 20mm depth at 1mm engage or the crankcase is most porn. 😀
                  #783391
                  Tiesman1986
                    Nice !!! 😀 are coming this summer to the VCM ?
                    #783392
                    sx3-swe
                      Don’t know.. this Ciao won’t be finished if I know myself right 😀
                      Could buy a 1 way flight ticket, buy a Ciao in NL attend VCM, then ride it home to Sweden, haha.
                      Last toolpath fortoday is finished.
                      Resized_20190126_204956
                      #783408
                      Crullie
                        Nice and shiny, simply lustrous   😛
                        TICKLING BARN
                        #783411
                          You’re making some nice stuff right there 🙂
                          Do you know a YouTube channel 2strokestuffing? His English is a bit zwedish kind of or something. He’s building a ultimate 41mm cilinder.
                          I think you’re building a really nice moped
                          #783416
                          sx3-swe
                            Thanks!
                            Yes, I’m familiar with his channel,he do some really nice and interesting stuff, way out of my league!. 🙂
                            He lives in Norway, but 1km from the Swedish border so you guessed good.
                            #783418
                              Thats some really nice progress you made:thumb
                              #783423
                                Very nice to see a carter come to life, tanks for sharing :thumb
                                How far are you today?
                                #783426
                                sx3-swe
                                  I agree, nice to see it come alive.. although there’s alot left still. Put some fine cuts on it today, and started out the cylinder boring, holes for the dowel pins and chamfer at the bearing seat as seen on movie.
                                  Resized_20190127_155258Resized_20190127_173203
                                  Resized_20190127_192812
