- Dit onderwerp bevat 238 reacties, 30 deelnemers, en is laatst bijgewerkt op 5 maanden, 4 weken geleden door zevenenergie.
8 oktober 2018 om 11:11 #779253
Yes, It’s too much angle on the carb… Dellorto says max 30 degrees, but 0-20 is preferred!
This manifold is a TPR for AM6.. TPR has one for horizontal where the rubber is more angled.. I have ordered this rubber and hopefully it will be perfect and it doesn’t incline negative.I will fit the motor in the Ciao before I mill the final carter, but for now I need to finnish all the fitments, with bearings, oil seals and so on.
Further on I’m working on some “improvements” the holder for the stator is more sexified and allows for more airflow
.8 oktober 2018 om 21:31 #779283Looks nice, do you use solid works?
9 oktober 2018 om 00:46 #779291Looks awesome😍👌🏽👌🏽 I am very curious to see how you will modify the frame to make the engine fit without sacrificing too much structural entegrity. I look forward to future updates!
9 oktober 2018 om 08:08 #779293@zevenenergie, No I’m using Autodesk Inventor.. But it’s basically the same thing. 🙂
@jaffabaffa, yes that is indeed a chapter of its own, there will be pretty decent amount of power packed into the frame so there will be need for reinforcements anyway.The carter inclines 20 degree where the membraan goes. The AM6 intake rubber has 40 degree angle. Therefor with this setup the carburator will be angled 30 degrees. That is maximum angle of what Dellorto states, but they recomend 0-20 degrees.
So the intake rubber for a horizontal Minarelli is angled 58 degrees + 20 degree on carter gives a carb angle of 12 degrees. I think this will be perfect, even though I think it looks more racing with inclined carb.
9 oktober 2018 om 10:04 #779301For tuning sake I would angel the membraan space in the blok a littel more if possibele.
.For if the intake rubber make,s a bent, the mixture wil go to one site of the membraan and get al the mixture. It is better to even out as much as possible, by making the airflow straight. 😉
Also is it a good idee to make the distance between te membraan and the carburateur as schort as possible.
and to have a membrane with many valves.
But I think you know this alrady.9 oktober 2018 om 19:19 #779331I hear you, but if I inclinde the bracket, I must also raise it.. If I raise it I will get bigger volume in the carter = less crank case compression.. I think I will go with this design.. One day I will hopefully test it on Dyno, then I’ll eloborate with both intake rubbers but also VL18 vs Vforce3 membraan.. I think the VL18 is a good choice aswell..
Today I received the rear clutch to collaborate with the front Scooter variator. 🙂
Last week I ordered a 2Fast 70cc cylinder, tuned by Hendrik Keller in Germany.. Hopefully he will prepare the cylinder this week.. Since he won IDC last weekend in both Dragrace and Scooter I think it will perform 😛
17 oktober 2018 om 20:49 #779580Santa claus came early this year. 🙂
I have realized that the reed valve needs more room, so I redesigned the inlet. Instead of covering the crank it’s a more Malossi C-One inspired reedintake. Some other minor improvements done, such as tolerance for bearings and oil seals.. And oh.. A slightly different design.. Noone will notice the difference. 🙂
Next step? Order some aluminium and check the tolerances once again.
Then let my friend start the mill..18 oktober 2018 om 00:09 #779589Good to see that your know-how helps you with your 2stroke desire to perform like no other.
All I can say is that I like it very much and will definitely follow your progress
keep Up the good work, let us know,….Succes 😛
TICKLING BARN18 oktober 2018 om 10:08 #779592Very Nice to see how you do iT all by your self making the engine ! Can wait to iT running 😀
18 oktober 2018 om 14:36 #779598Nice cilinder… 😛 Ik think this carter looks even better.
. If I can be so bold, how much does it cost to mill your design?18 oktober 2018 om 18:19 #779608Thanks guys!
If I let a company machine this for me then this would be aprox theese prices:
1 piece: 964€
5 piece: 380€
10 piece: 300€In my case me and my friend trade services.. he owes me 50 hours on the machine because of work I have done for him so I’ll only need to buy the raw material which is like 240€ worth of aluminium. (Fu*king expensive with aluminium :D)
19 oktober 2018 om 15:52 #779646Do I hear that well € 240,- for 10 pieces of aluminum ? 😛
If so, then maybe I will reserve a crankcase?!, Is that possible ?.
You can mark mine as 007TICKLING BARN19 oktober 2018 om 18:53 #779652Then you’ll have to get on a plane here to Sweden and be a Slave for the machine operator for 20+ works hours. 🙂 Should I reserve 007 for you then? 😉
I wish that I had the possibility to offer this crankcase for other people, unfortunatly my friend only machine for a hobby and not for the money. He machine in change for help with something he needs help with.
I can ask him next time I slave for him, how much he would want in cash to make cases other than to me. I guess it will be expensive though, something in parity with above pricing of 1 piece.what I pay is 240€ for the raw material.Which is quite close to thoose 300€ incl machining if order over 10 pieces. However I would need a fully functional prototype before considering producing larger volume.
Or maybe I just give away the 3D files free, contributing to the community just like the Fan for thoose who wanted the files and let people arrange the milling on their own. 🙂
20 oktober 2018 om 00:51 #779667I know what you are saying, I will stay calm and follow the progress of the proto type.
Sweden, love it, the country of Husaberg and Husqvarna, very good material 😎
And certainly interested in those 3d files as the prototype is running
TICKLING BARN20 oktober 2018 om 12:29 #779678Tanks for sharing this price information.
I must say, the price of a 1 milling is substancial.
I gess it won,t be an option to look at the drawing carefully and use a dremel to keep the price down 😉If you are going to share the 3D files I whoud deffenetly be interested. 😯
But who knows, maby you find a way to make a produktion serie. -
