:: SX3’s Ciao perso [English]
Home Forums Perso’s Projecten SX3’s Ciao perso [English]
15 berichten aan het bekijken - 91 tot 105 (van in totaal 239)
  • #779039
      The thing wiht cilinders is, you get what you pay for.  To coat an old cilinder with Nicasil cost minimum 200 a 250 euro,s but can cost as much as 900 euro,s.( It come,s in 0,1 to 0,5mm)
      I know people that pay €1600,- for a Kreidler cilinder or more. And a aditional 300,- fore the tuning.
      That someting looks good, doesn,t alway,s meen that it is.
      Im not so familiar wich schooter cilinders, but i would advise you to go to a scooter dragrace event and ask e aboud the best cilinders to buy.
      The cilinder is inportent, but if I wanted to go fast I would invest  money in an good exhaust too.
      #779065
        Aah no, it was a response on ritze’s take on Malossi. I know your initial choice was between a 2fast and stage6 R/T.
        Today there are a lot of choices when it comes to cylinders. All but to new for my taste since i had personal experiences with older cylinders. At the time it was mostly Malossi or Polini and still they make good, fast and reliable cylinders. I would not say go for a Malossi, but what is your goal eventually?
        #779170
        sx3-swe
          Goal, I don’t know.. I like to build stuff and thats probably the main goal.. Hell, I remember when I was 15 and immortal (atleast I thought i was), even then a 43mm+13mm felt like a death wish on a ciao when peaking speed :D, and now 18 years later I don’t think this ahve changed, It might even have gotten worse 😀
          I have been looking at Roost, LMR, Nini GP, LP, 2fast, Polini P.R.E but still haven’t made up my mind.
          I have even played with the tought of maybe redesign so that I geet water connection in the cylidner base like the Piaggio engines, then I’ll be able to adapt flange mounted cylinders.
          But probably I’ll just go with Minarelli design and don’t make things that advanced.
          Anyway, my mockup is beeing printed 🙂PART_1538638188380_Resized_20181004_092918
          #779173
            Nice, but we realy need more pictures.
            #779174
            Tiesman1986
              Nice ! Look foward to the result.
              #779175
              sx3-swe
                Me too, can’t wait to get my hands on theese 🙂
                1234
                #779178
                  Nice print, it would even looks nice on your night stand!
                  #779179
                    This is verry nice to look at. Tanks for scharing.  What is the next step going to be?
                    #779180
                    sx3-swe
                      @Martino, Thanks.. 🙂
                      @zevenenergie
                      , Next step is to testfit crankshaft, membraan, intake, carb ignition and so on, to make sure there are no collisions (collisions in both parts and my brain)..
                      The step after that is to get me a cylinderkit so that I can make sure the cylinder fits with that thing pointing out in front of the membraan and also make sure I get correct squish and that the bore in the carter is sufficent for the cylinder to slide in.
                      2fast, roost, 2fast, roost.. I think I might need to toss a coin to decide..
                      #779182
                        Make it a 2fast 😉  and keep hitting us with pictures of the test fitting of the crankshaft, membraan, intake, carb ignition and so on.
                        #779225
                        sx3-swe
                          Cylinder have been ordered, it will be 2 weeks before I get it… It will be tuned before it leaves the shop 😮 😮
                          Anyway, I started to test fit some parts, so far so good! There are 1 thing I noticed so far and it’s the angle of carburator which is too steep.. This intake is a Top performance for AM6.. The rubber for the same type intake but for horizontal Minarelli is more angular, I will order it today and hopefully It will straighten upp the carburator so much that the bowl will be withing 20 degrees.
                          IMG_20181007_145111_974IMG_20181007_145111_973IMG_20181007_145111_979IMG_20181007_144201IMG_20181007_144137IMG_20181007_144121IMG_20181007_144051IMG_20181007_091811
                          #779237
                          Tiesman1986
                            Looks good! ,maybe a stupid question regarding your title but is  this going to be on a ciao ? Or a other moped?
                            #779239
                            sx3-swe
                              On a Ciao 🙂
                              #779243
                              Tiesman1986
                                And is the ciao going to be original looking or just totally race.
                                Looking forward to see the engine in the frame , because of the nice things sticking out 😀
                                #779244
                                  Oh my! This looks so good. Show us some pics in the Ciao if possible.
                                  Isn’t the carb on too much angle? Or will it lean more backwards?
