:: SX3’s Ciao perso [English]
Home Forums Perso’s Projecten SX3’s Ciao perso [English]
15 berichten aan het bekijken - 151 tot 165 (van in totaal 239)
  • #784131
    sx3-swe
      Mirror mirror on the wall……….Resized_20190217_150148Resized_20190217_150157Resized_20190217_150210Resized_20190217_150219(1)IMG_20190217_095628IMG_20190217_095654IMG_20190217_100441
      #784135
      sx3-swe
        Fixture for milling The other side of The carter.
        Resized_20190217_181332Resized_20190217_181458
        #784137
        ktmgek
          Nice work.
          #784164
          Crullie
            Next to drill is the wheel hub/disc brake adapter I see. :thumb
            How far is the Ciao frame ? anny reinforcements to the frame for the many many horsepower engine ?
            Will keep looking forward but also patiently waiting for some !!!
            TICKLING BARN
            #784235
            sx3-swe
              Which holes are you referring to?
              The frame is, as is in earlier post in the thread.. I’ll need to finnish the carter before I know where to reinforce because I will need to cut the frame a bit to fit the carter in place because of double sided crankshaft.
              Some more progress on the carter, starting to look like the 3D model.. Exciting, if it won’t work, it will still be one sexy piece of metal to have on the shelf 😀
              Resized_20190217_190633Resized_20190217_190614Resized_20190219_192041Resized_20190219_192823Resized_20190219_200901Resized_20190219_210229
              Resized_20190219_214024Resized_20190219_214717Resized_20190219_214708
              And a small video..
              #784295
                It’s stays satisfying to watch, like an episode of Discovery’s How it’s made.
                1
                #784455
                sx3-swe
                  Hehe, well then it’s time for next episode 🙂 Now it’s really looking like the 3D model, it’s satisfying to see  something go from sketch in computer into something you can touch!
                  One side is almost finnished, only som chamfers and a screwhole left!
                  As usual, a small video clip in the end.
                  IMG_20190223_181259_resized_20190224_101552986IMG_20190223_135940_resized_20190224_101553201IMG_20190223_181313_resized_20190224_101553421IMG_20190223_183123_resized_20190224_101636144IMG_20190223_183127_resized_20190224_101636351IMG_20190223_191124_resized_20190224_101636570IMG_20190223_191128_resized_20190224_101635919IMG_20190223_191133_resized_20190224_101708804IMG_20190223_204351_resized_20190224_101708577IMG_20190223_214620_resized_20190224_101709037IMG_20190223_214607_resized_20190224_101708367IMG_20190223_214629_resized_20190224_101708170
                  IMG_20190224_102739
                  #784459
                    It is as if I am in a nursery and a new world citizen has just been born.
                    And it has a Vfrorce pacifier 🙂
                    Do you have a name for this carter?
                    #785620
                    sx3-swe
                      It’s been a while since last and it’s mostly because we had a major set-back with tolerances.
                      The machine seem to miss steps or there is a bug with backlash compensation.
                      The seatings for the bearing were ofsetted with about 0,35mm on Y axis.
                      We have corrected this by re-milling the “keys” to oversize and making custom keys, instead of Minarelli original Keys for this EVO-1 carter. So now we’re back att decent tolerances at 0,02mm for the bearing offset.
                      But we haven’t found the problem yet though, so still need to troubleshoot.. We do encounter some missed step here and there,but they are not in places tolerances are needed, only estethical.Resized_20190330_171633_01
                      Resized_20190330_202549Resized_20190330_202431
                      #785635
                      sx3-swe
                        Couple of more picturesResized_20190331_165857Resized_20190331_165851Resized_20190331_165903
                        #785637
                        Tiesman1986
                          Looks great ! , hope for the best and I know for sure you figure it out soon !
                          #787101
                          sx3-swe
                            We are behind the schedule because of problem with the mill.. We have big noise and vibration that are escalating. We have changed tension washers on drawbar and also bearings on the spindle.. Hopefully we can start test the machine within next 2 weeks. Haven’t given up on the carter. 🙂
                            Meanwhile, I have bought a new Ciao, meant to be a daily driver… A 2002 Ciao with elec. ignition.
                            I was only going to change bearings av seal and have a look inside the engine, but I ended up ordering;
                            – DR 43mm
                            – 13/13
                            – Polini head with centered spark
                            – 80 polie + malossi snaar
                            – Polini airfilter
                            – Citypower exhaust
                            And a couple of more stuff..
                            60563982_10156998511422347_8889511996869836800_n
                            #787121
                              I am sorry to hear of the problems whit the machine, but what doesn’t kill you, makes you stronger.
                              The Dr 43 is an excellent choice, and wil give you lot,s of joy.
                              #787127
                                Shame about the machine. But good news on the Black Beauty. I have the same ciao, but with black wheels. That setup will be legendary. 43DR is (i’m sure) the most popular cylinder. Performance is great  😎
                                  That’s absolute gorgeous! Very nice design. I’m eager to see it in a thin flexible Ciao frame 😉
