:: SX3’s Ciao perso [English]
Home Forums Perso’s Projecten SX3’s Ciao perso [English]
15 berichten aan het bekijken - 136 tot 150 (van in totaal 239)
  • #783443
    sx3-swe
      1 side of the first half is more or less finnished, chamfered the bearing entry and dowel pin entry.
      No we just need to figure out how to flip the piece and re-align it within decent tolerance. 😀
      Resized_20190127_223458
      #783444
        You can index the seal ring seat, the the clamp holds the direction.
        #783452
        sx3-swe
          Yes, thats probably how we’ll do it. Will need to make a plate with same hole pattern så we can bolt it onto it.
          Here are 2 more movies for those who like to watch this carter come to life.. 🙂
          #783492
            Cnc video,s are so satisfying  to wach 🙂
            1
            #783573
              I, am ready for the next video 🙂
              #783576
              sx3-swe
                Haha, yes me too! Don’t know how many times I’ve watched thoose vdeos.
                However, there won’t be any videos any day soon unfortunatly. Next step is to machine the inside of the next carter half, so basically it’s the same toolpath but mirrored. Same same but different, not so exciting.
                As I mentioned in October, my mill-man trade machine hours for help he needs and can’t do himself. During this fall/winter I’ve helped him migrate the CNC from NFS Mach3 to Mach4, to operate the CNC-mill. Basically I’m finnished with my work, as the 3-axis is up and running as earlier (4 to be honest A-axis works too nowadays). I got so in love with developing the machine so managed to put my self in a situation were I promised and convinced him to integrate the ATC (Automatic tool changer) aswell. (haven’t been in use for 10+ years, since the machine got retrofitted with Mach3).
                So I’ve been sitting during the nights learning LUA programming and the Mach API and started to write some M06 Tool change macros.
                So, this saturday we have decided to test and try parts of the M06 macro, manage to rotating the tool carousel.
                Since the carousel isn’t a coordinated axis (XYZABC) but a out-of-band axis, it’s a bit tricky to keep track of it’s position with only counts. But If we are sucessful with the tests, we will spend last hours milling the carter. If not sucessfull he willl continue milling the carter on sunday and next week, which he will do anyway since he lives 80km from here, I can’t go over everytime we gonna mill.
                I promise to keep the thread alive with every progress on the carter. 🙂
                #783609
                Crullie
                  Computer chips and their language right ?, Argh   😈
                  Just keep going.
                  Good luck and Success   :thumb
                  TICKLING BARN
                  1
                  #783672
                  sx3-swe
                    Made a visit to carter yesterday.. Here we can see that the engineer (me) have been drunk again, the VL18 reedvalve is one hell of a big reed membraan, it will need a raiser to not hit the crankshaft..
                    Will order a V-force3 membraan and also a raiser.. I think the V-force don’t open as much, because of more opening area.IMG_20190202_111026_resized_20190203_123349619
                    #783680
                      This kind of things happen to me all te time. (learningcurve)
                      #783682
                      Tiesman1986
                        Good luck ! I know for sure this is going to be your best journey ever :p.
                        Just like mofafreak I always looking out for a new post from you.
                        #783686
                          Still all is looking good and the little problem with your intake is indeed simply overcome with a raiser/spacer. Keep on going you getting there! :thumb
                          #783978
                          sx3-swe
                            Thanks Guys,
                            Inside of the other half should be finnished upcoming days.. But it’s just a mirror so it’s basically the same.
                            3D printed mockup parts are finnished, will test them this weekend.Resized_20190214_084716
                            #783982
                            Crullie
                              Sow I have to wait 2 days ?    I think you just want our affinity   😛
                              Looking Damn good :thumb
                              TICKLING BARN
                              #783986
                                Nice parts :thumb can,t wait to see them in aluminium.
                                Where is the left hand part for?
                                #783992
                                sx3-swe
                                  @Crullie, ofcourse. 😉
                                  Left part is the adapter bracket for the caliper, see 3D rendering here:
                                  https://vespa-ciao.nl/forums/topic/sx3s-ciao-perso-english/page/9/#post-783005
