:: Stronger subframe for my Bravo.
12VTopic starter
JelleModerator
citta en bravo subframe are the same (only the centre stand stoppers are different)
The jmpb subframe doesn’t fit properly for vario.
12VTopic starter
I will run it with a vario setup in the future, so that is not good news. Is the material too thick, space issues between the frame and pulleys? It’s already very close on a stock thin sheetmetal frame.
JelleModerator
That correct, the material is just to thick…
So when you buy a subframe like those you have to adjust it.
12VTopic starter
I found a used original one in good condition, so i’m good for now 🙂
