:: start problem
Home Forums English General questions start problem
  • #144213
    think
      i have a ciao i can run it to its start but when i stop the enige stop to ?
      #145533
        still not good enough to say thats the problem.
        #145534
        think
          what do you won to now ??
          #145535
            does the engine directly start to turn when you start to push it? It could be that there is something wrong with your clutch.
            Maybe the distance ring between the clutch and the flywheel is the wrong way around.
            This disc has an upstanding side which must be towards the clutch. When it’s the wrong way around the clutch get’s blocked and can’t turn free..
            #145536
            think
              I can get it to drive when i running by the side, but when i stop running the motor turns off.
              #145531
                if you give some gas it makes a mwoaaaaap and goes dead?
                #145537
                think
                  yes?
                  #145529
                  neogod
                    did you try to start it with your choke on? (the red button near your feet) ever looked at the airfilter? is it nice clean? Tried to look at the nozzle if it isnt blocked up? and does your floater work correctly?
                    #145538
                    keltow
                      Have you let go of the compression handle while running ? 😕
                      43mm cilinder = 4.3×((0.25×π)×4.3^(2)) = 62,45cc
                      #145539
                        have you tried a larger spreader yet?
                        check your sparkler what coller is it?
