- Dit onderwerp bevat 11 reacties, 9 deelnemers, en is laatst bijgewerkt op 15 jaren, 6 maanden geleden door virgil.
15 september 2010 om 15:10 #147433
Hi everyone, I am excited because maybe i kan get a sponsor, which would supply me with 2000 Euros if I will win scooter races with a “special” Bike. Up here in Denmark all is driving Yamaha Aerox/Jog ect. So what could be more “special” than beatin their ass in a Ciao?
Ofcourse it needs a hell of a engine. Im thinking Sprocatti. So heres my questions:
– Where can i buy them?
– Are the motors with everything like crankshaft, clutch ect??
– I’ve heard it is a hell to adjust the engine, is that right? (Needs to know it, so I can get help from a Pro-tuner)That’s all of my questions. Thanks for helping 🙂
15 september 2010 om 15:13 #147884http://www.sprocatti-motori.com/
It only seems that there service is the big problem.
So u can try, but dont be to exited.Barry ( Moderator ) from this forum had one and he sold it, he knows more about this engine.
15 september 2010 om 15:25 #147885Hmm, Maybe i should just use the Simonini Engine, or what about The Zirri engine? Any place where I can buy that?
15 september 2010 om 15:28 #147886Finding a Zirri engine is like finding the pot of gold underneath the rainbow. 😛
A Simonini engine is definetly the best option, atleast its easy to get one.
15 september 2010 om 15:32 #147887Hmm, god damn it! Well maybe i should just improve my Polini Speedengine with a Simonini Side-inlets. Sorry i keep changing my mind, i just want to be a little more special than other Ciao’s in Denmark. Where can i buy the Simonini Side inlet? I keep searching on Google, but with no luck.
15 september 2010 om 15:45 #147888You can’t buy the side inlet new anymore. The production stopped a few years ago.
15 september 2010 om 15:53 #147889simonini 2007 cases including malossi spruitstuk.
new @ JMPB.NL.15 september 2010 om 15:54 #147890If you whant to sprint against scooters you should buy the simonini 4 taps carter and not only a simo side inlet because than you can only choose from the 3 taps cilinders
http://jmpb.nl/store/index.php?act=viewProd&productId=2287If you want you can bild a scooter cilinder on it. Maby speedbuxy can tell you more about it.
15 september 2010 om 16:32 #147892Sprint racing with a vespa is somthing you have to do for your own fun becourse you wil never win.
The vario transmission of a vespa is nothing in comparing with a scooter transmission.
And even when you fixs this transmission problem(fox clutch)than you still have the problem that the inlet of a simo 2007 is much smaller than that of a scooter.15 september 2010 om 18:39 #147893if i was you i take a sprocatti engine and fix a fox clutch but i think you can’t buy it easy because its bad communication.
so just as speedbuxy says, you don’t make a chance against a scooter.
succes with it.
15 september 2010 om 19:39 #147794or heuvel 😉
yes indeed, i was thinking bout Sprocatti LC with the Parmakit 50mm Cilinder..
I thought Barry here @the forum ever had a sprocatti engine? Is this correct?15 september 2010 om 20:04 #147793yes indeed, i was thinking bout Sprocatti LC with the Parmakit 50mm Cilinder..
I thought Barry here @the forum ever had a sprocatti engine? Is this correct?Is it so hard to just read a little bit more? Let’s say only this topic. 😕
