:: Sprocatti disc mounting
Home Forums English General questions Sprocatti disc mounting
  • #144329
    Kamelen
      Does anybody know how I mount the disc compared to the piston ?
      When the piston is down I guess the disk should be at the back(open) and when it is up it should be closed ?
      I have no idea but I have a sprocatti carter at home..
      #145827
        Its the same as an original motor so when the piston goes up the inlet opens and when it goes down the inlet closes.
        The disc fits the hexagonal bolt so does that mean you have 6 positions in which you can mount the disc?
        #145876
          Piston @ TDC
          Piston @ BDC
          Disclaimer: These are pictures Fredzzz posted a couple of years ago, they may not be correct.
          Jarco
            Edjuh :
            This is correct, only dont forget you can ’turn’ ( Mount it in a difrent angle. ) the hexagonal bolt before mounting it on the cranck.
            Actuly i hope to see the correct answer in this topic, cause i also have to deal with this some time on my 3 stud rotating carter..
            #145840
            Kamelen
              Thank you guys for answers 🙂
