:: simonini calibrata?
Home Forums Techniek Opvoeren simonini calibrata?
  • #185080
    ciao1981
      hallo
      Ik heb een complete motor Malossi (47mm deps, 19phbg, vliegwiel pinasco, Polini variator)
      Wat uitlaat raden jullie aan voor deps 47mm, 27mm uit?
      simonini calibrata( 30mm ,uit deps?)
      #201128
        This would be a nice fit. Keep in mind there are also Calibrata’s available with already an 27mm or 28mm diameter flange.
        #201134
        RaymonBlaauw
          ja, dat raad ik je zeker aan
          #201135
          ciao1981
            dank u voor uw reactie
            Waar vind ik een uitlaat(simonini calibrata) die perfect past in de uitvoer cilinder? (27mm)
            De uitlaat 30 mm zal geen lekkage van gas uit een 27mm(Uitlaatflens Deps 27MM) cilinder?
            #201136
              There should be some sellers on ebay.it who sell the correct versions of the Calibrata. Also some other internet shops will sell them, but you might need to mail them for the correct sizes.
              I don’t know what you exactly mean by your last sentence.? The online translators are not always sufficient, so writing in English would be an option.
              Using a 30mm exhaust on a 27mm flange should not be advised. As a solution you can use a cylindrical bus so the difference is tightened .
              #201138
                For a cheaper option, you could shorten a leovince exhaust. ArvidW showed in his perso a shortened leovince is almost the same in shape and performance.
                This is mine, with a 25mm flange.
                Arvid’s
                He reached 100+ with a tuned DR cylinder and a peugeot fox vario clutch.
                I have yet to test mine(on a 42mm polini), will be somewhere in spring.
                #201139
                ciao1981
                  thank thank!!!
                  i have the “ninja usine”
                  I made ​​a drawing tomorrow, I find this a good performance exhaust
                  bye
                  reed valve powwer:D
