:: simonini 48 in original block
Home Forums English General questions simonini 48 in original block
  • #144298
    Cruisarn
      Hey, i wonder if it’s hard to get a simonini 48mm cylinder in original block + eurocilindro turbo inlet?
      does it need welding, or will chemical metal/plasticpadding(?) on the outside of the block be enough to strengthen it?
      #146041
      pepko
        do you mean the 3- or the 4 taps(’07) engine? the ’07 is available on JMPB.
        There’s only one model for 3 taps which have a 48mm bore.
        #146042
          tnerual
            isn’t that a SpeedEngine?
            #145661
              Yes the big half is from a SE carter. Personally i prefer an original carter since the compount of the Polini carters is somewhat softer and tends to break more often at the cilindertaps.
              #146044
              Cruisarn
                I mean the 3 taps 😉
                Okey so it isnt too hard to fit in the simonini into original block? and no welding is needed? Doesn’t understand dutch to well, can only see the pictures 🙂
                #146045
                dieseltank
                  http://translate.google.nl/?hl=nl&tab=wT#
                  van nederlands, naar zweeds i hope it help…?
                  #146034
                  Cruisarn
                    Using google chrome, translates automaticly but it isnt very accurate :/ but it seems it could work, seen people using the kit in org block without welding or pasting so 🙂
                    #145667
                    Jarco
                      The only thing you need to do is milling and adjust the ports. :thumb
                      But be careful.
                      #146047
                        I have seen people putting this cylinder on original carters, speedengine’s and evo’s. I myself have an Evo with Simo, but as is said you need to mill the bore of the carters and with the Polini carters this would be a weak spot at the taps. I did’nt need any welding.
                        Also look at this perso of Piet30 He did also fit a Simo on Evo and most of the text is in english.
