:: simolini carter and scooter cranksaft
Home Forums English General questions simolini carter and scooter cranksaft
  • #144305
    00Andre
      hello 😀 l have a question
      l talk about a normal 44mm stoke , and if it is to big and not fit the carter
      will l put it intro a turning lathe and make it fit 🙂
      l will coures remove the right site of the cranshaft
      but the my big question is :
      do the scooter crankshaft fit intro the bearing , in the carter ?
      (simolini carter)
      ty , André 🙂
      #146077
      dieseltank
        I expect so, you might be on finding the right bearings
        and ofcource, you will driving with a front vario of a scooter…?
        #146078
        00Andre
          the simolini carter use 6202 bearing ,, and a scooter use 6204 … 😀
          and yes coures 🙂
          #146079
          00Andre
            l will put the carter intro a turning lathe and make it fit.. 🙂
            #146080
              I’m afraid it won’t work, the crankshaft of a scooter is wider than a vespa crankshaft.
              The simonini carter has 2 sizes of bearings! One small one (6202) and one large one (XXXX)
              Then you are milling away the aluminium your bearings are housed in
              Comparisson of width between honda NSR50 crankshaft and Simonini2007 crankshaft:
              I think the NSR50 crankshaft has near identical dimensions as for example a minarelli horizontal crankshaft
              00Andre
                what do you meen with that ?
                the carter is in aluminium
                #146082
                  Width : Not die diameter of the crank but the distance between the insides of the bearings.
                  00Andre
                    hmm l will cut the right site of the cranshaft off (ignition site)
                    do you understand 🙂 ?
                    but it will not work `?
                    #146084
                      You don’t understand me, i’m talking about the part of the crankshaft that is actually inside the crankcase.
                      00Andre
                        yes l don´t understand you .. :S
                        but where can l an crankshaft Simonini race 44 ?
                        or somthing els that fit a simolini carter , with the stok 44 ?
                        #146086
                          This is the problem: I am pretty cerain that the red width is larger than the green width
                          Milling the crank down is with most cranks very difficult because they are hardned. Milling the engine is no option because then there is to little space te mount the bearings.
                          I’ve had a 44stroke simo crankshaft, it was a simo crankshaft made for the old simo engine. This crankshaft is also available in 46mm stroke. All simonini crankshafs for vespa are 74mm in diameter.
                          The left one = simo 44 strok, The right one = malossi 43mm stroke (and 70mm in diameter)
                          00Andre
                            hmm ok 🙂 do you know where l can buy an old simo crank ?
                            waht about this cranksaft: http://www.speedline.dk/da/scooter/krumtap-motoforce-standard-oe10mm-mf30-19400/
                            its not so wide 🙂
                            #146088
                            virgil
                              Hi,
                              I read the mail you send me on youtube.
                              I think you have to look after a crank that is small but even strong.
                              Next i have seen a vidio on youtube of a Italian man that have made a scoot crank in hit reed valve engine.
                              If you ask me, it is posible but you have to find of a cnc machine or a crank that have te good mesurements.
                              The bearings i wood make the crank a litle smaller so the original will fith in it.
                              Think logic.
                              Greetz.
                              #146089
                              00Andre
                                ok thanks :=)
