Home › Forums › English › General questions › Sense of fox clutch
- Dit onderwerp bevat 8 reacties, 3 deelnemers, en is laatst bijgewerkt op 12 jaren, 7 maanden geleden door Piet30.
8 augustus 2013 om 10:15 #144199
Hi,
general questions for my understanding to use a fox clutch.What are the general advantages in using a fox clutch?
Is there an advantage in using a fox clutch modified on a 10,5:1 er mono gear box compared to a standard 100mm vario with 10,5er vario gear box?8 augustus 2013 om 10:20 #146469The general advantages are increase in top-speed. The range of the pouli’s are far greater then that of a 90MM of 100MM clutch. thus creating a ‘longer’ gear.
ArvidW has driven his Citta with a fox-clutch and 1:13.5 gearing around 100km/u if i’m correct. He did this with an modified DRevo, and an shortened Leovince Circuit.
downside to this is that the clutch weighs a lot more, so the needle-bearings inside your mono gear box will wear a lot faster. I was thinking about putting an SKF closed ball-bearing inside the gearbox, where the long axle will come out.
But i don’t have the equipment to weld Alu onto the gearbox. so that’s a no-go for me. scooters use this also. they just have a normal crankshaft bearing mounted in their gearboxes.Also you’ll need to adjust a few things to have it working. So it’s not usuable ‘out of the box’.
Other than that, it’s a wonderfull transmission. basically you use a better designed clutch, instead of the 20 year old variomatic.
8 augustus 2013 om 10:39 #146470Ah,ok.
To use the larger range of the clutch pouly, is a Malossi or Polini variator able to support that?8 augustus 2013 om 11:20 #146471as far as i know yeah, the Malossi (in my case) is able to support the larger range of the pouly’s. At least a lot more than a stock piaggio one.
i don’t think the malossi or polini variator take optimal advantage of the fox-clutch, but if you can drive 100km/u on a citta with 1:13.5 gearing then i’m guessing it’ll be fine!i’m driving with a stock vario-clutch now, but that’s only because i don’t have a kick-carter, and the fox-clutch doesn’t support starting the motor by running with it.
8 augustus 2013 om 11:25 #146472Sounds good
Thanks for that infos.
8 augustus 2013 om 17:57 #146473Exactly what niels said only I used stock 1:10.73 “snor” gearing.
The initial drive ratio when driving of from a standstill is very low. I was able to outrun a 43mm DEPS on a sprocatti rotary carter upto 50km/h with my 50cc primerally due to this light gearing.
Home made engine dyno8 augustus 2013 om 21:54 #146474haha 😀 bad thing for the sprocatti rotary driver. 😀
Yes, I know your Citta with the 50cc and fox kopeling very well from former nice tours we made together. But didn’t realize that it was a snor gear box.
8 augustus 2013 om 22:07 #146475In my opinion “snor” is the only way to go if you want to take full advantage of the advantaged of the fox clutch. As niek already stated on a citta you run out of the gearing around 100kph if you have a high reving engine (approximately 9-10.000rpm for my DR639 engine). On a Ciao it will be more like 125kph which is simply rediculous for a 40kg moped :lol
Owning a fox clutch variomatic is a bit of a love-hate relationship. The performance is really good however at speed it vibrates like hell, bearings last 1500km or so, axles sometimes break, starting without kickstart is a bit of a joke and fabricating the axle can be a bit of a challenge. Furthermore the “torque drive” slots wear out quite quickly.
It may sound like it’s a bit of a problematic system and it sometimes is, however I would build one again if start working on vespa’s again.
Home made engine dyno8 augustus 2013 om 22:19 #146476Cool, I like to run my Sprocatti Evo with it, starting will be with a hand drilling machine. So no problem with that.
Will not need to put a screw into the clutch and follow it after engine is running 😀Also will not reach the 1000 km mark with that engine so fast.
Thanks for you input on that topic.
