:: Search someone who can realis a pipe for me
Home Forums English General questions Search someone who can realis a pipe for me
  • Dit onderwerp bevat 10 reacties, 5 deelnemers, en is laatst bijgewerkt op 19 jaren geleden door coda.
  • #144093
    Ciao_Man
      Hello All! I search a person who can realis a pipe 16 mm for my speed engine polini carter.
      http://www.mijnalbum.nl/Foto=Y43RZLTT.jpg
      It’s for put a 16 mm carburator. I offer € if someone makes this pipe!
      Thanks you!
      #145374
        Making such an intake manifold isn’t too difficult. The only important thing we need to know, is the outter diameter of the pipe. The inside should be 16 mm off course, but the outside size depends on the carburator’s inside size.
        Also the length of the pipe is important, even as the (possible)angle.
        Give me the right measures and I could make you the desired manifold.
        #145375
        Ciao_Man
          It’s for a dell’orto carburator, you know?
          http://www.mijnalbum.nl/Foto=AMDJPPZZ.jpg
          You must make 20 degrees angle…
          This is instructions to realis this pipe:
          first of all, you got to find a metal plate, and make a square just like the original one.
          you drill 3 holes in it, 2 for the screws, and 1 for the pipe.
          you find a pipe with a diameter of 16 on the inside, and on the outside the inside diameter of your carburateur. and weld the pipe on the plate. with an angle of ca. 20 degrees.
          #145377
          .-{2F4OV}-.
            I had a 16mm intake before;)
            But I sold it to TimoO on the forum, maybe you can buy it from him:thumb
            Here a link to the page
            #145387
            barry
              The piece is make.I take my dell-ortho carb for the measures.Here a pic of the mounting.
              #145388
              TimoO_
                that looks realy nice :D. did you made it in an angle, or was it not necessary?
                #145392
                Ciao_Man
                  barry :
                  very nice my friend, this is a good job but on the photo, this is a 21 mm carburator no?? because me, i want to put a 16 mm caburator?? reply me! thanks man:)
                  #145393
                  barry
                    This is my 16mm from JMPB! I have the same In 19mm also & the connection is the same!
                    #145394
                    TimoO_
                      but, would that carburator fit into the vespa?
                      #145395
                      Ciao_Man
                        barry :
                        Ok very good, no problem my friend! Very nice;)
                        #145396
                        coda
                          Well done Barry!
                          I also have a carb like that,I bought it once,but never used it.
                          I want to mount it on my speedengine,but wil it fit in,or do I have to remove the airfilter?
                          Is it possible that you can make me one,and what would the price be?
                          Greetz
