Home › Forums › English › General questions › Scooter trasmission on vespa ciao
- Dit onderwerp bevat 9 reacties, 7 deelnemers, en is laatst bijgewerkt op 16 jaren, 5 maanden geleden door Picod43EVO.
18 oktober 2009 om 15:48 #144228
hi all, How do I mount a clutch scooter on vespa ciao?
Link
thanks 😉
18 oktober 2009 om 15:51 #145587that is a VARIO.
You can buy these at a two-weeler schop(bromzaak) and online, but they are very expensive.18 oktober 2009 om 16:05 #145588I think he’s asking how to mount a Fox clutch on a vespa ciao, not what it is (in fact, it is a vario clutch, a part of the variomatic system).
Well, if you want to mount a clutch like this on your vespa you need to buy a Fox axle: the axle this clutch originally is mounted on. Then you got to attach the part you mount the clutch on, to the gear part of an original Vespa vario axle.
18 oktober 2009 om 16:08 #145589Peter.S :
that is a VARIO.
You can buy these at a two-weeler schop(bromzaak) and online, but they are very expensive.Can you put the site link?
thanksWhat Benefits implies this transformation?
sorry for my bad english18 oktober 2009 om 17:39 #145590jmpb for example.
but you can look around on this site for an occasion.
that is not that expensive.an new variomatic system +.- 400,- euro.
than u got an mollossi systembut you need another rear gearingcase. a good one costs between 85,- and 150,- euro
more as 150,- you don’t got to pay for it, more is not fair.
and newones don’t exists, they’r not in production anymore.this is an link to a part of v-c.nl how you got to mount a variomatic system,
its dutch but maibe u can translate it.http://www.vespa-ciao.nl/forums.php?m=posts&q=8186
also you can see on the pictures the parts u need.
this is a site where you can buy all the stuff, exept the gear case.
http://www.jmpb.nl/store/index.php?act=viewCat&catId=43
this is what you need
achterkoppeling cpl imi vespa 49,-
malossi variateur vespa 59,-
V snaar vespa 15,- (order the good vsnaar for your model moped)and the pressure spring in the rear clutch, is not so good.
u can better instal the yellow one what’s included by the variomatic kit.I hope u can moveon whit this information.
you can PM me always for more quistionsltr
18 oktober 2009 om 19:08 #145593Picod43EVO :
sorry for my bad englishHanno piu possibilita di variare che puo dare piu velocita, e sono piu facile a tarare.
Si trovano a seconda mano.
Cmq non hai gia provato una variatore piaggio per ciao? Non sono perfetto ma adattare quelle dei scooter e costoso e difficile, e non mi convinci che sei un elaboratore a dita magiche.
18 oktober 2009 om 20:11 #145594You will have to combine 2 shafts:
You can weld them togetter, use threads or press-fit them.
Home made engine dyno19 oktober 2009 om 15:15 #145090Edjuh :
Picod43EVO :
ahahahah simpatico! 🙂
era solo una curiosità infattigià lo ho il vario per vespa ciao!
19 oktober 2009 om 17:17 #145595Edjuh e simpatissimimo come se fosse un italiano DOC….:D
La curiosita e donna, dicono gli italiani credo eheh!Ma secondo me questo e un forum olandese, magari serve di creare un sezione per italiani, vedendo il fatto che c’e anche posto per tedeschi e inglesi…!
Invece voi italiani siete forti!!!!
22 oktober 2009 om 12:35 #145597ahah grazie a tutti
