:: roterende inlaat measures
Hy guys, I’ve opened this topic because I need some
measures about the simonini rotary disc intake. (I hope is the right room)
Here there is a photo of what I need.
http://img64.imageshack.us/i/img00203m.jpg/
Please…if you can help me, try to be very accurate by measuring.
Thank you a lot!
EdjuhBijdrager
Why not ask gab pei or ivano?
Gab made a copy so surely he knows best.
Most simo rotary carters are owned by italians.
I forgot it:lol
Anyway if someone has got it…post it.
Meanwhile I’ll ask to Gab.
I’ve measured my Eurocilindro rotary disc intake. Wich i think is the same as Simonini.
Taking your foto in mind from left to right i found te following data
4mm
96mm
11,4mm
20,5mm (but this is not a perfectly shaped circle)
2mm
11,3mm
Somewhere on the italian forum i found some scetches from the imitation version. But i thought this where from Gab-pei afterall.
Off: Where do you need this data for?
I need these data to build one.
Thank you martino.
