:: Rotary disc attachement
Piet30Topic starter
Hi, does somebody know how the rotary disc in a rotary vane engine is fixed on the krukas?
I think it is very difficult as the rotary disc need to sit exact in right position to open and close the inlet.
Also I do not see any space on our standard krukas to fix the disc. Is there maybe a special krukas needed?
If you look in the topic, Crullie had one..
You have too drill a hole inn the crank where you must fix the special nut…
Look under roterende inlaat bevestiging there you can find it 😉
Just a ori crankschaft will do, you need a special bearing SKF-explorer 6003-2RSH / C3.
Don’t mind the centerbold, its not needed.
First you press the disc-holder in the bearing, then press bearing with disc-holder around the crankshaft in the only right way :! Timing is considerable in this move.
The lower foto it is Top Dead Center done the ride way but a few degrees tolerance depending your own cilinder-timing is possible.
Succes Ralph
Piet30Topic starter
wow, thanks for the infos.
But how is it possible to get the right inlet timing?
I think it is difficult to set the assembled disc-holder with bearing on the krukas without having a degree reference. 😐
Difficult to say the exact degree number’s offcourse, depending the stroke, cilinder-timing, cc’s, carb,, muffler, ignition settings and the fact that there are different disc’s with different inlet periods, but this system will work without knowing the numbers.
Inportent is that one of the 6 points from the disc-holder is exactly in-line with the center of the big-end, then you have only find the one of 12 position’s from the disc like on the foto to have the right timing.
I promise you, it will work just fine.
Do you see the centerpoint’s all in line with top dead center ? this is the way to mark de disc and disc-holder for the next assembling.
Piet30Topic starter
aah, thanks Crullie, very good advice
