:: RE: Sprocatti Motori
Home Forums English Pub talk RE: Sprocatti Motori
15 berichten aan het bekijken - 1 tot 15 (van in totaal 21)
  • #147435
    Maarike
      Hi everyone, I heard that i should buy the Simonini Engine instead than the Sprocatti:
      But!! I got a Question:
      With the Simonini Engine, does I get crankshaft and flywheel with the Simonini Engine (just like the Sprocatti here http://sprocatti-motori.com/Kit_completo_ciao.htm)
      If not, could you guys help me making a Shopping list, it’s a completely standard Ciao can gonna be delghted with the simonini or sprocatti.
      Thanks for helping dudes 😉
      #147895
        Simonini delivers a complete engine! built up too, so it’s plug & play(if your frame is ready for it).
        Choose Simonini, it’s a guaranteed stunner!
        #147896
        tnerual
          Or try the Sprocatti, why not.. with that attitude nobody will ever try that engine..
          I thought Barry here at the forum had had a Sprocatti LC motori
          #147897
          Maarike
            Think I’ll just will be on the safe side, i’m only 16 years old, can’t afford to loose 1000 euro for a motor I can’t get to run probably. On the Simonini Engine, Isn’t it just a hole in the frame to the Caburateur and membran?
            #147898
            cittajuul
              no because youre cooling fins are to big for youre frame
              so you need to modify youre frame more than only a hole for the carburator
              #147899
                tnerual :
                When reacting, please come with some arguments. As you can read in several topics on this forum, sprocatti has horrible service. Don’t expect customer comes first at sprocatti…..
                @Maarike
                Please do some proper research about this engine, there are already allot of people which bought and are driving this engine.
                Fire up google translate and start reading these topics:
                http://vespa-ciao.nl/forums.php?m=posts&q=3133&d=2750
                http://vespa-ciao.nl/forums.php?m=posts&q=17373
                http://vespa-ciao.nl/forums.php?m=posts&q=7801
                #147900
                  tnerual :
                  Jij hebt geen flauw idee waar je het over hebt, ik wel en ik weet dat er een hoop verloren euro’s in sprocatti zijn geinvesteerd! ik heb barry’s correspondentie met sprocatti gevoerd omdat ze geen engelse mails konden schrijven dus ik ken de houding t.o.v. klanten die 1500 euro bij hun besteed hebben. Daarnaast heb ik ook verhalen van italianen (uit eerste hand, niet op internet gelezen) die nog minder positiefs bijdragen, tot en met vormen van oplichting door de heer franco himself.
                  Dus ik heb genoeg gezien om te blijven zeggen: Gun sprocatti geen cent.
                  Als er iets is verbeterd geldt voor mij: eerst zien dan geloven. Maar ga gerust je gang en bestel iets moois als je er iets van denkt te weten.
                  #147903
                  tnerual
                    en heeft barry’s blok nooit gedraaid zoals het hoorde dan?
                    #147904
                      Onze fred-ex heeft hem met veel hulp aan de praat gekregen, daarna nooit meer iets over gehoord.
                      Filmpjes staan op youtube.
                      #147906
                      tnerual
                        bedoel je de filmpjes van 3-5 seconden?
                        of andere??
                        want als eht andere zijn kan ik er wel geen vinden..:S
                        #147907
                        Citta_lennart
                          *Das een evo blok.
                          #147908
                          CrossVespa
                            Waar zou dat blok eigenlijk gebleven zijn?
                            #147910
                              Gewoon bij Frederick onder zijn Citta.
                              #147909
                                Topic is posted in the english section, perhaps for the TS it is better to post in english :@
                                #147803
                                reiniero
                                  I went to the scootershow in keulen and his citta was also there, en this time he built it with a HPI ingnition, I talked to him and he told me, the motor just ran with the hpi, here some pictures :
                                  http://www.mijnalbum.nl/Album=3UXGQFLT
