:: Question to HPI inner rotor ignition
Home Forums English General questions Question to HPI inner rotor ignition
  • #144313
      this ignition set from JMPB does have a CDI unit and a ignition coil.
      http://www.jmpbonderdelen.nl/hpi-ontsteking-vespa-ciao-simo.html
      I have not much experience with ignitions, but I thought that a contact ignition has a ignition coil and a electronic ignition has a CDI unit.
      Does anybody know for what both is necessary in the HPI set?
      #145552
        You need both on this set. The CDI which holds the 2 or 1 curves and the ignition coil. In this case, there is only one curve availble I thought. You can buy seperate boxes which hold different curves. Or even a programmable one.
        This type of ignition looks like a Berini for instance.
        On an original Piaggio motor the cdi unit also contains the ignition coil. They are combined as one.
        #145207
          ah,ok, understood. 😀
