:: Question over electronic motorblock
Home Forums English Pub talk Question over electronic motorblock
  • #147476
    chris79
      Can i mount 38,4 DR cylinder on electronic motorblock? Will it fit? Or i can mount only a standard cylinder?
      #148146
        It all depends on what type of carters you have? There are so called “limited carters” out there. You need to find out by just trying to mount the cylinder. If it isn’t possible, you can simply sand it dowm a bit so the cylinder will fit. For the carters that is.
        #148143
        chris79
          Thank you for the answer. Well, i think i have bromcarters, as my moped has yellow license plate and carburateur is 12/12.
          #148188
          xinix
            Then you can go up to 43 mm max ( 70 cc), and a 38,4 mm (50 cc speed)you can run 4sure ofcourse.
            #148190
            chris79
              Well, glad to hear it!
