:: Proper vario adjustment
Home Forums English Pub talk Proper vario adjustment
  • #147495
    rubymax
      Hello,
      I mounted the new malossi multivar for my Piaggio SI. My current set up is:
      – DR EVO 43 with port matching
      – dellorto 13/13 + malossi air filter, widen carb intake
      – SITOPLUS exhaust
      – 90 mm vario with malossi contra yellow spring
      – electronic ignition
      At the moment I have in multivar 7g rolls but it is still overreving and there is not top speed like i have with Polini UTAH vario. Shall I go higher with rolls weight? What do you guys suggest me regarding my set up?
      Thanks in advance!
      #148260
        I would personally take out the Yellow Malossi spring, and replace it with a stock one as the stock spring is enough for this setup. Or find an exhaust that can handle more RPM.
        #148261
        rubymax
          Hello,
          What do you think if I just tried to put the 8g or 9 g rolls and leave the yellow spring?
          regards
