:: Proma Circuit, Please help!
Home Forums English General questions Proma Circuit, Please help!
  • #144241
    bmoney
      Im having a hell of a time trying get my proma circuit on my 70 ciao “leak free”. I replaced the hardware on the clamp with 10 grade hardware and clamp it down REALLY tight, Like to the point i’m scared the spigots gonna snap.. I’m also using a heavy duty spring to support it. If i put my finger over the end of the pipe the bike remains running, and you can hear it get louder from the spigot / header area.
      This leak is robbing my power and causing my temps to go through the roof. I hit 400F after a short bit of riding at WOT.
      Please, any suggestions to get this thing leak free??
      Thanks in advance!
      #144827
      niek1992
        here in NL we’ve got ‘uitlaatpasta’ or also called exhaust cement. it looks like this; .
        spread a little bit exhaust cement around the flange of the exhaust, and mount it. wait a few minutes. Then start is. LET IT IDLE! otherwise the compression blows the gasket away, as it hardens.
        When it’s fully hardened you’ll have a leakfree flange!
        The stuff is usually bought at carmaterial shops. Or webshops! I have the luck of working at a car-garage.
        Succes!
        #146172
        bmoney
          Thanks for the info and quick responce. I’m sure there is something similar to that exhaust cement here in the US. Ill certainly look into it..
