:: Proma CC For Bravo
Home Forums English General questions Proma CC For Bravo
15 berichten aan het bekijken - 1 tot 15 (van in totaal 18)
  • #144299
    Storek
      Anyone know if Exhaust Proma cc can go on bravo? And where i can buy a new one?
      #146048
        Yes it’s possible to fit this exhaust on a bravo. Only the original Proma is not in production anymore so you have to buy it’s replica from Tecnigas. http://www.jmpb.nl/store/index.php?act=viewProd&productId=1817
        #146049
        Storek
          Oh thank you! One more question. It looks like this store is sending in Slovenia too. But because i dont understand dutch language can u tell me u need to pay first and they send or how is going?
          #146050
            Just use the frontpage http://jmpb.nl/store/index.php and klick the flag for english on the top left corner.
            It should be pay first before they will send.
            #146051
            Storek
              Thanks! WHat about variomat? Where to order it?
              #146052
              Spulleke!
                a complete variomatic set isn’t able to buy aymore ur can buy a couple of imitation stuff but that is all.
                #146053
                CittaKlaas
                  You can order almost everything you need for it on the same website, http://www.jmpb.nl/store.
                  But since not everything is sold there, and because its quite expensive as well, you could search around on this forum.
                  They are offered here as well, as a complete set most of the time (second hand).
                  #146055
                  Storek
                    #146060
                      Storek
                        Thanks, right now when i was building machine i broke piston ring. Piston size is 38.8 this means thath i need to get ring size 38.8? Because i wasnt able to find ring 38.8
                        #146063
                          It looks like you have a surplus sized piston rings. Normally this would be 38,2 or 38,4. This makes finding the correct piston rings somewhat difficult. You can try to send an e-mail to JMPB for this size, but i’m not sure if they even sell these.
                          #146064
                          Storek
                            Which cilinderkit u recommend for bravo? Because i think i will buy complete new.
                            #146065
                            tnerual
                              If you want to go 65cm³, and customize your crank case, i would go for the Polini or the DR 43mm cilinder kit.
                              #146003
                              Storek
                                What u mean with customizing crank case? So this is DR 43mm http://www.jmpb.nl/store/index.php?act=viewProd&productId=599 .
                                And it fits to Bravo? What about cilinderkop ? Is same as default piaggio bravo ?
                                #146066
