:: polini water cooled…
Home Forums English General questions polini water cooled…
  • #144253
    bowie82
      what kind of crank pulley are you guys using for your water pumps? im running a water cooled polini, but the only thing stopping me is hooking up this water pump. is there anywhere i can buy one? or can i retrofit something? thanks for the help.
      #145804
        Hi,
        you do not necessarily need a water pump to run that cooling system.
        Hot water is going up and cool water is going down by physical rules in that system without a pump. 😉
        #145805
        bowie82
          so then whats the point in running one? would it make a difference if i’m using this bike for very long trips, and not just racing? thanks for the help.
          #145806
            The point is helping the termosifon process with some extra flow. Let’s wait and see what the LC users have to say.
            #145807
              If you are interested in the pulley on the crank. Kevinwol on this site made one that is an exact copy of the polini pully that comes with the set official. So if you are still interested, you could ask him if he maybe could make one for you.
              #145803
              citta-ehv
                bowie82 :
                hello I am willem I can water pump come to zown and those costs 95euro ex send costs. I have myself also a water cooled polini seal have, with water-cooled seal have with own radiator and water alleys and hydraulic pump. the water pump which I buy have is new in packing and is orgineel of polini. this water pump will not find you also online or in the shops. these are very rare and the question is there large to, if you have intresse in the pump that I it hears, however
                edit:
                this pump is new and sits everything at entirely complete clamps hang and affirmative material, also the small poelie which you must assemble your crankshaft . there you v come lie string. and thereby if drive you then you twist crankshaft. and then you twist hydraulic pump also.
                #145808
                tnerual
                  sorry off topic, but a 38mm polini LC??
                  #145809
                  citta-ehv
                    here the orginele are construction drawing of my polini seal which I have had. such as your mischien on the drawing will it can see for 41mm a cylinder. there an original test bijzit report and those give to the set to that almost 4 pk have and the top is 85 up to 90km at a good adjustment. at the power test to see you also that table which indicates how the engine reacted nou that is, however, clear seems me. it was an aluminium cylinder cooled head with pours steel hollow cylinder and an aluminium piston further drunk everything: gaskets, coolant, water alleys expansion barrel, radiator, the water pump, in short everything
                    #145810
                    tnerual
                      so there is a 38mm AND a 41mm polini LC cilinder??
                      http://www.treatland.tv/vespa-piaggio-polini-38mm-50cc-water-cooled-kit-p/vespa-polini-50cc-h2o-kit-ciao.htm
                      but i thought there was only a 41mm LC ?? From Polini I mean
                      #145812
                      CIAO-OPC
                        FF Offtopic ziet wel gaaf uit die web site. web site looks nice =)
                        #145813
                          There’s only a 41mm Polini LC kit. Don’t believe everything they put on the net! :con
                          Anyway i thought there are still a lot off sites who sell this pump. For instance Link.
                          #145814
                          G-no
                            Wrong, there is a 38mm Polini LC. The point is that they are even more rare than the 41mm one’s!
                            #145815
                              Well that’s new for me. Thought only the cylinder heads where 38,somewhat? Do you have some more info? G-no
                              #145816
                                VespaAvanti owns a 38mm polini LC kit, it is practically the same as the polini41mm LC only the bore is smaller. It is quit similar to the polini38mm AC
                                  I’m quite sure that Speedbuxy also has both kit’s, the 38.2mm as well as the 41mm and both brandnew.
