:: Polini top one on 70 ciao,
Home Forums English General questions Polini top one on 70 ciao,
  • #144189
    pink floyd
      Does anyone out there know if a polini top one will fit my 1970 ciao with 19″ wheels?
      There’s not much room between the head and front wheel, and i don’t want to spend my
      “weak” pounds on a pipe that doesn’t fit!
      Thanks, from Martin in the U.K.
      #145153
        I would say no, don’t fit.
        As I measure on my old Ciao with 19″ wheels there is only 6,5 to 7 cm space between head and fendor. The Polini Top One needs 7 to 7,5 cm space.
        I drive a Proma CC, that exhaust fits;)
        greets,Ralf
        #145154
        Helios
          I would also recommend the Proma cc.
          It’s a nice pipe and has a great boost around the 35-40.
          From that point its a straight line till max speed!
          #145155
          pink floyd
            Thanks for your help Ralf and Helios, I didn’t want to spend my money on a pipe that doesn’t fit!
            and as no one stocks parts over here, i can’t look before i buy. I would like a Proma cc, but
            i didn’t think they were made any more? or are they still avalable to buy some where?
            #145156
              You’re right, Proma CC’s are not produced any more and no one has them in stock…
              JMPB.nl told us that it will be made under a different name (Technigas) but they don’t know when the new exhausts will be available.
              #145157
                in Switzerland you can still order the Proma CC;)
                http://www.motoriluppino.ch/Shop.php
                klick here Proma CC
                greets,Ralf
                #145159
                pink floyd
                  Thanks Ralf, have you ever dealt with these people in Switzerland? I like dealing with the Dutch,
                  they are very helpfull and most speak some English, my Swiss is not good!!! Postage from Holland
                  is only £18/£20 which is o.k. too. I really need a pipe with good power low down, we have alot of
                  hills and i weigh 16,4lb i don’t know what that is in Kg’s, to much i think!!!
                  #145160
                    No I havn’t dealed with this specific guys from Motorluppino but with another Switzerland shop called Cycletech. The shipping cost and paying customs was very high.
                    And your shippment cost of about 22 Euro from Netherland to UK is less than I payed from Switzerland to Germany.8)
                    Due to that I also prefer to buy from Netherland, JMPB. They have good stuff, prices and excellent service. The bad thing is that they don’t have the Proma CC.:(
                    But nevertheless you can try to get a used one from one if this guys here in the forum. Sometimes they sell one.;)
                    greets,Ralf
                    #145161
                    Daan777
                      The PromaCC is only 87,50 Euro! =)
                      #145181
                      pink floyd
                        I now have my new Proma circuit pipe, my ciao runs alot better, I just wondered what size main jet I should be running with this set up, Malossi air filter, 13-13 carb, Malossi 43mm cilinder, Proma circuit. I think my Ciao is running a bit rich at the moment.
                        #145182
                        Svennoow
                          I would say around 68
                          #145183
                            Tip: use one or two parts of the steel filter from your original airbox in your malossi thing because it lets alot of debris through.
                            Nice setup, we’d love a little film of you cruising through the british countryside :- )
