:: Polini Lunga exhaust
Home Forums English General questions Polini Lunga exhaust
  • #144496
    Szasza
      Hello,
      would anyone have information about Polini Lunga exhaust.
      it might be good to have a DR evo cylinder
      best regards
      Sz
      #146894
        The Polini Lunga is actually a Polini Custom. Lunga is the name of the exhaust which is the long version. There are two types, Custom 1 and Custom 2 both availble in lunga(long) and corta(short). Also a version which goes the other way around. As for the results. This exhaust is beeing tested, but results where not as positive. Definitely not a good combination with a 43mm DR evo cylinder.
        In dutch but you can see the digets and a list of tested exhausts; http://vespa-ciao.nl/forums.php?m=posts&q=26010
        As for the line of Polini exhausts. There is almost always a better choice to be made, think about the Polini Top One for instance.
        #146892
        Szasza
          thx
          to be me Evo, 13 carb, polini airfilter, cut crankshaft.
          I would like a good pipe middle range
          #146895
            As said, go with the Polini Top One.
            #146896
            Szasza
              Polini top one is better then Fire?
              #146897
                It depends, when you look at top speed the Fire is the way to go, but Top one pulls away much faster and since you where looking for a good middle range pipe i’d go for the Polini Top One.
                #146898
                Szasza
                  thx
                  best regards
                  Sz
