:: Polini LC kit on Polini EVO ?
Piet30Topic starter
Hi,
do you think that a 41mm Polini LC kit could work on a Polini EVO block? Or is the 41mm kit to small for the EVO block?
Peter has a reedvalve engine with the 41mm polini.
It ran pretty good!
Piet30Topic starter
Piet30Topic starter
ok, just checked Peters special and it looks that he is driving a modified big Polini on the RV.
What about a 41mm cylinder on a RV or EVO engine? Does that make sense? 😕
Piet30 :
Before he drove with the 41mm LC on his RV. Your 41mm should run proper without any problems.
Else see his youtube channel, for more info: http://www.youtube.com/user/peter0139
erikbloemberg
