:: Polini Evolution engine
Home Forums English General questions Polini Evolution engine
  • #144447
    Italjohn
      Where can you buy the Polini Evolution engine?
      I can’t find it no where???
      Or is the malossi engine a better buy?
      #146304
      johan 007
        I also searched for the polini evo engine but i cant find where they sell them i think there is nothing where u can buy it
        Malossi is easyer but be sure that u have a complete set and everything fits i heard there are older versions and some parts doesn’t fit on the newer so be sure u have a complete set that fits
        A
        #145246
          Did you tried Ebay.it?
          Or try to send a PM to Gab-Pei http://vespa-ciao.nl/users.php?m=details&id=4965
          #146691
            Do you want to buy a Polini Evolution Engine? Because you already have this project with a Speedengine from Polini. With a little work you can fix a bigger carb onto this SE. I will found out there is little no difference in performance between these carters and had better scores with the SE over the EVO.
            Still, if you want to buy a new EVO enginge? This will be more difficult, but second hand you might find there are options. I could hook you up perhaps.
            #146692
            Italjohn
              Thanks for the feedback 🙂
              I was just playing with the thoughts to buy a new Evolution engine, and manage to find one online 🙂
              But if you say it’s no better then the Speed engine, I will stick to my Speed engine for now.
              But again, the Malossi engine looks better design with it’s huge reeds, compare to polini’s small ones.
