:: Polini crank case
Home Forums English General questions Polini crank case
  • #816284
    Goran-swe
      Hi.
      the instructions for assembling a polini crank case is to heat them up to 250 degrees. That seems a bit hot? Does italian use Fahrenheit?
      #816292
        250 should be Fahrenheit indeed it seems e bit high a temperature. Even 130° Celsius is a bit steep. Just above 100° Celsius is enough. Definitely for Polini cases, these are a bit softer then original cases.
        #816355
        Goran-swe
          I wrote to polini and they responded it is 250 degree Celsius.
          anyway, before I got their answer I heated it to ~150 and it worked fine
