:: Polini case. Malossi cylinder
Just saw that the Malossi cylinder doesn’t match with my new polini case. It’s different form on the cylinder foot and it will not be air tight. Sigh.
Guess I will order a polini cylinder.
What polini cylinder kit do you recommend?
I got:
polini case
Athena “racing” crank shaft
13mm carburetor.
Do I want a kit with cylinder head included, or is the original as good?
Depends on which malossi cylinder. 2020 type 46.5 mm fits the polini cases well, the 43 mm brevettato doesn’t. Original cylinder head can be used for 38 – 43 mm.
JoeBijdrager
This is the polini case I’m working on with a malossi 46.5 cylinder.
