:: Piontek’s vespa si
Home Forums Perso’s Projecten Piontek’s vespa si
91 bericht aan het bekijken (van in totaal 91)
  • #489869
    piontek
      hansieb :
      @piontek
      You mean jet size 50 ? With this setup:
      41mm DR
      original carters
      original crank shaft
      1212 carb opened up till to 13mm or something more.
      giannelli mega or leovince exhaust
      Variomatic transmission made of polini utah and original clutch.
      electronic ignition with lightened flywheel.
      This needs like a 64-66 jet.
      Well….now I have the normal clutch with the pulley.
      I haven’t allready mounted the variomatic.
      The carb. is the original one 1212.
      I ‘ve bored the inlet manifold of the carter up to 13 with the intention of mounting a 1313 maybe in
      the next future.
      Regarding the jet, I agree with you infact I started with a 62 but was too much.
